1995 Grand Marquis Transmission issues
I have a 1995 Marquis and some pretty bad tranny problems..
It slips pretty bad from 2nd to 3rd and 3rd to 4th gear. If you accelerate quickly, it doesn't slip at all. I was wondering if there was any factory defects or maybe some tips that anyone could give me. Also, should I get a rebuild?
Do you have any transmission codes showing on a scan? Solenoid malfunctions; valve body problems are common issues. Have you tried changing the fluid - Mercon V, including the converter? There was a TSB about 3-4 shudder and problems suggesting a complete fluid/filter change. Play around with the overdrive switch off see if there is differences.
