1997 MGM, Fuel Pump / Powertrain Control Module
Old May 10, 2016 | 06:57 AM
Johnw's Avatar
Default 1997 MGM, Fuel Pump / Powertrain Control Module
Hello All, I'm new to this forum but I feel I'm pretty adept at this kind of repair but this one has me pulling hair that I don't have.
Fuel pump not running, checked for power at the inertia switch (because it's easier to get to than the fuel pump), I'm only getting 6 volts there. Back-tracked to fuel pump relay, I have good power to the coil that energizes it but only 6 volts to the common pin of the switch which tells me that the wire from the relay to the inertia switch is OK. That's supposedly fed from the PCM. I ran a wire from + on battery to the wire from the inertia switch that goes directly to the fuel pump and the fuel pump started right up and so did the car. That tells me the fuel pump is fine and the problem is in the controls somewhere. Could it be a bad PCM? I don't see any grounding point on the PCM either, I suspected a bad ground but now I'm getting a little stumped.
Sorry if it's a little windy but all replies are appreciated
Thanks,
John W.
Mid-Michigan
Old May 16, 2016 | 06:34 AM
conan312's Avatar
So you've ruled out FP relay?
kryichek
Mar 22, 2023 10:21 AM
borg_99
Feb 15, 2010 08:42 PM
Deezyofphilly
Oct 12, 2009 05:58 PM
jferline
Sep 27, 2009 07:10 PM
Smokefan
Apr 7, 2009 06:02 PM
