2003marquis blower motor
Old Mar 15, 2010 | 01:56 PM
yarktown7's Avatar
Default 2003marquis blower motor
the blower motor only works on high. is it the resitor if so where is it located thanks i would appreciate it
Old Mar 15, 2010 | 07:59 PM
check this post over on p71interceptor.com
you should have the solid state one that looks like the pictures in this post.
Old Mar 16, 2010 | 07:46 AM
orten999's Avatar
Default College Term Papers
You have to contact blower motor company because this is not a low matter.
College Term Papers
Old Mar 18, 2010 | 07:51 AM
yarktown7's Avatar
i whant to thank you for your reply i sorry i didn t get back to thankyou earlier. i found out that it is a manual system. is the resister still on the outside heater housing i dont see it.thanks yarktown
Old Mar 27, 2010 | 07:29 AM
mecka nick's Avatar
Yes it is. Right behind the passenger side cylinder head. A bear to get to & you'll think it wont come out of there but it does. 2 screws with 8mm [5/16] heads on them. IIRC you need to get a couple other components out of the way to get the resisitor out of there. Be glad you have the manual climate control. The control heads for the automatic systems go for $400+
Old Mar 28, 2010 | 05:52 PM
yarktown7's Avatar
thanks mecka nick when it stops raining and gets warmer i will ck. it out. by the way i have owned marquis for years i never had one go. figure this one is the newst. i gess there making them in china know, like everything else thanks again! dan
Old Mar 29, 2010 | 10:03 PM
mecka nick's Avatar
No prob. Have changed a couple. Usually the blower motor is the culprit but if it only works on high it's the resistor. We have them in the fleet. Pretty good cars except for heater cores or blend door motors. Keep your cooling system flushed regularely
yarktown7
Mar 15, 2010 01:44 PM
don1957
Jun 19, 2009 07:06 AM
1996 green sab
Aug 13, 2008 12:50 PM
stephx0x0x
Jul 2, 2008 09:40 AM
western
Feb 23, 2006 12:28 PM
