Battery light comming on
Old Oct 9, 2006 | 12:53 AM
  #11
cpettymore7777's Avatar
these alts do have internal regs. if you take the alt off you can get the reg out, (only 2 torx bolts). autozone sells the reg. it is a electronic device, so you really cant tell if its bad by looking at it. and with all the time you put into this so far, $20 might fix your problem for good. at the very leastisolate one issue.
Old Oct 10, 2006 | 09:51 AM
  #12
VaDancer's Avatar
Thanks cpettymore777, I have been told that it may be the regulator in the alternator. I do know that when it comes on I actually am overcharging the battery. I think I will go to Auto Zone and pick up a regulator and install it soon and see.
I also have another problem that occured a few months ago. The door locks, key pad, and autowindow down system does not work anymore.I checked the circuit breaker and it is good, I even replaceditto be sure. Is there an inline fuse somewhere I can check?
Thanks for your help.
Old Oct 11, 2006 | 08:06 PM
  #13
i would have to look at a schmatic as i haven't run into that problem YET. if i find something i will post it for you if someone does not beat me to it.
almightyzulu
Mar 15, 2014 11:57 AM
murkeree_owner
Mar 10, 2014 12:00 PM
colby2302
May 31, 2009 01:06 PM
invidregent99
Jan 18, 2007 05:46 PM
invidregent99
Jan 9, 2007 03:43 PM
