Brakes lights not working - switch?
Haven't logged in for a long time, to answer question that has probably been taken care of by now: The brake lights and other functions such as hazard are controlled by the switch inside column activated by turn signal lever/arm. That whole lever assembly has to be replaced by taking apart the column housing (pulling the ignition switch) etc. It is doable if you are careful and follow manual instructions to save a buck. If you find that you do not have brakelights and your car (trans) will not go into gear___ that is the switch that is connected to your brake-pedal that is in need of replacing. Also doable with a flashlight and patience. Hope this helps.
heh, heh. Yeah, contorsion city on that one. I had to leave the little spacer/sleeve off the replacement, would not slip in place with it on. Does not seem to need it for smooth operation, just in case anyone tangles with that particular repair.
