DRL
Old Oct 26, 2007 | 02:21 PM
coupe's Avatar
Who can say me how the DRL is working?
My MGM is build in Canada and i think, it must work, but it is not working
Edited by: coupe
Old Oct 26, 2007 | 04:37 PM
92Mercury's Avatar
All Grand Marquis are built in Canada, see here:
http://en.wikipedia.org/wiki/Mercury_Grand_Marquis
Dlr - dealer installed option, is that what you meant?
This refers in general to options the dealer installs, not the factory. For your year and model: Seat Belt Extenders
Basically it's a buckle with a small piece of seatbelt, which clips into the buckle installed on the car, it extends the seatbelt. For larger people, to give you less pressure on the seatbelt, and in PI's used to accommodate more space for the sidearm officers are wearing.
Also for easier access to the factory installed buckle, as it's partially underneath the front armrests, due to the bench seat.
Greetings!Edited by: 92Mercury
Old Oct 26, 2007 | 06:03 PM
Duffy's Avatar
Daytime Running Lights??
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
Old Oct 27, 2007 | 03:01 AM
coupe's Avatar
ya, daytime running light
92Mercury's Avatar
Don't think so, MGM doesn't have any. Even the details for the 2008 model don't list them.
Well, we'll find out. If he says that "it is not working", he can probably clarify. I hope LOL
Greetings!
Old Oct 27, 2007 | 03:05 AM
coupe's Avatar
don´t know, if installed or not. but i think, because manufactured in canada
Old Oct 27, 2007 | 03:07 AM
92Mercury's Avatar
Manufactured in Canada, but for US market.
Nerveless, MGM does not have daytime running lights.
If you want them, they make wiring kits which you can install.
Easiest solution is: turn your headlights on. [img]smileys/smiley8.gif[/img]
Greetings!
Old Oct 27, 2007 | 03:20 AM
coupe's Avatar
okay, i will do that[img]smileys/smiley14.gif[/img]
Old Oct 27, 2007 | 12:44 PM
  #9
92Mercury's Avatar
All that theharness (wiring kit) is doing, is supplying power to your headlights only. So none of your tail or instrument lights would be on.
Greetings!
Old Nov 14, 2007 | 06:25 PM
  #10
92Mercury's Avatar
Update for the DRL (DaytimeRunningLights):
I just happen to run across this section in the Shop Manual (it's from 1998 and states "applies to all models '92 to present":
Daytime Running Light System (Canadian vehicles only):
The Daytime Running Light (DRL) system is designed to turn on the high beam headlamps ON, with a reduced light output, when all of the following conditions are met:
-The vehicle is "running".
-The vehicle has a fully released parking brake.
-The headlamp system is in the OFF position
NOTE: If you have a vehicle with an automatic lighting system, the DRL system is active until the automatic system turns on the headlamps.
Greetings!
