Help, disability requires adding a dash mounted START switch
Old May 12, 2012 | 03:38 PM
bobdec's Avatar
Default Help, disability requires adding a dash mounted START switch
My wife's arthritis is making it very hard for her to start our 2003 GM. Getting the ignition switch to the on position is not a problem, but it seems this vehicle has a very hard and awkward ignition switch 'START' position for a physically challenged individual. My idea is to just add an aftermarket N/O switch. I will supply +12v ignition voltage to one side of the switch, the other side of the button would splice into the ignition 'START' wire. So she can insert the key/turn the ignition on/ then push the start button till it starts and release the button. Turning off the key will stop the engine. This is a manual start setup requiring the correct key chip and turning the ignition on, nothing like the newer buttons in later vehicles. I have done some searching and it looks like this car has a single red/lt blue 'start' wire coming from the ignition switch that I would splice the button output into. Problem is I can not find a schematic or wiring diagram of the ignition circuit to insure this is correct. Any other ideas or links to schematics that will help me will be appreciated.. Thanks, Bob D.
rollerhockey90
Apr 30, 2010 06:52 AM
joelg
Aug 8, 2009 09:27 AM
ealfuth
Jun 15, 2009 07:33 PM
jason sereiko
May 22, 2008 09:36 PM
srch4aresn
Jun 4, 2007 08:00 AM
