How to disable DRL
Old Mar 27, 2010 | 03:35 AM
BilalMGM's Avatar
Default How to disable DRL
Could you please tell me how to cancel the Daytime Running Lights on a Mercury 2008?
Old Mar 27, 2010 | 08:03 AM
mecka nick's Avatar
Find the signal wire for the DRL that comes from the PCM or the trans position sensor & disconnect it. I don't like those things either. They cause folks to drive around at night with no rear lights.
Old Mar 28, 2010 | 07:01 AM
BilalMGM's Avatar
Thanks Mecka mate,
But sorry to ask, where can I find the PCM (Powertrain Control Module) as I don't have the car manual on me anymore and how to trace the signal wire?.
also for the 2nd option do u mean the trans sensor? and where can I also locate this?
TIA
Old Mar 29, 2010 | 10:15 PM
mecka nick's Avatar
If you're going to do this kind of work on your car you'll need a manual. I recomend a factory man. The pcm is on the firewall right behind the d/s wheel well. The trans. pos. sensor is attached on the d/s of trans where the linkage attaches but with no diagram that's kinda useless. I'll try & remember to look up the diagram tomorrow & see.
Old Apr 4, 2010 | 01:25 AM
BilalMGM's Avatar
Did you manage to get a diagram of what wire to cut/sensor to disconect to get the DRL's off?? Thanks.
Old Apr 4, 2010 | 10:26 AM
mecka nick's Avatar
The DRL works through the lighting control module [LCM] & are actually the hi beam bulbs getting sent a lower intensity signal. I looked at the connector views to try & find a wire but didn't see one labeled DRL. I could send you the connector views of the trans sensor/LCM & you can see which circuits get voltage when you put it in drive at the TS & LCM. Just make sure if you cut a wire you do it so it can be spliced back if it doesn't work.
Old Apr 30, 2010 | 07:04 AM
termpapers's Avatar
Term papers
Old May 13, 2012 | 01:21 AM
Cannon's Avatar
I know I'm digging this up from the past but has anyone figured this out yet?
Old May 21, 2012 | 09:14 PM
  #9
leoqmoa's Avatar
I think so, and I also have the doubt with you.
baginz
Apr 12, 2018 07:20 PM
02mounty
Jul 30, 2010 09:57 AM
coupe
Nov 15, 2007 01:00 PM
