Moaning and Stalling
Old Nov 13, 2007 | 02:12 PM
92Mercury's Avatar
This is about 2 common issues, have been discussed on here before.
1.) the "moaning" noise (see other posts)
2.) erratic idle and stalling
There is a new TSB out there, applies to all models 1992 through 2003 or '04. I will get a copy tomorrow, then we know for sure.
It calls for inspection and eventually replacement of the "air-injection-pump". Whatever, something new now LOL
I happened to find out about that yesterday, when my colleges car was brought to the shop, because of stalling and erratic idle. He had them fix it, $175 for the pump, they got it from the dealer.
Will post details once I have them. Mine is going in tomorrow to, because of the moaning noise. Have the dealer check out the whole system, just to be sure. Parts can be bought about 60% cheaper aftermarket, see other posts.
Greetings!Edited by: 92Mercury
Old Nov 14, 2007 | 11:49 PM
92Mercury's Avatar
Yep, it's the IACV (IdleAirControlValve), sometimes refered to as AirBypassValve, the box says "Throttle Bypass Valve".
Around $55 brand new:
[img]uploads/92Mercury/cv10120m.jpg[/img]
Greetings!
Old Nov 15, 2007 | 10:52 AM
92mercmadman's Avatar
so thats what caused the irregular idea and stalling??
-cheers
Old Nov 15, 2007 | 11:05 AM
92Mercury's Avatar
See my original post, the TSB is about thedifferent causes, all related to the same part.
A work colleague of mine just had the same issue, with the stalling, a '02 MGM, same part replaced, all fixed now. Paid around $240 at a NoName shop (I was quoted around $175 at the dealer). See, sometimes dealers are not that bad (sometimes). LOL
Have you been drinking today? Seems like you're missing quite a bit. [img]smileys/smiley8.gif[/img]
Old Nov 15, 2007 | 11:49 AM
No i have not been drinking! lol.
But its been a rough day we had to have one of our dogs put down today.
so its been rough.
-cheers
Old Nov 15, 2007 | 01:05 PM
92Mercury's Avatar
I'm sorry. Did you have it for long? Strange thing, isn't it? Once you have an animal for a while, it truly becomes a family member.
My issues, after they re-tightened the bolts, are much better. I still have a slight missing when under load and in overdrive, but idle and starting issues are gone.
The noise almost disappeared, now that it's colder. I'm currently doing research on where the item is located on our cars, I found sources for the part itself already.
Will let you know.
Greetings!
Old Nov 18, 2007 | 09:05 AM
aquaistq's Avatar
I have a 1991 Grand Marquis which "lopes" at low idle and then dies.
How do I determine if the IACV is bad?
98mountianeer
May 16, 2016 06:39 AM
Rocker210
Jul 3, 2010 07:29 AM
Charlie3
Oct 27, 2008 12:34 PM
luy123
Jun 10, 2006 09:34 PM
marinodx13
May 25, 2005 12:14 AM
