Rear end vents fluid.... Why
Old Mar 8, 2019 | 11:57 AM
ru4mercurygm's Avatar
Default Rear end vents fluid.... Why
It appears rear end oil is venting out of the top of the rear axle left side .......
Im not sure why..... is there a vent tube or hose that prevents this from occurring???????
Old Mar 11, 2019 | 05:06 PM
Originally Posted by 95 MERC
Aloha 95 Mercury......
After accelerating up mountain to home...... I smelled oil coming from rear driver side.
looked under car and saw what appears to be rear end oil running down axle housing.
I friend said there should be a vent weep hole on top of the axle housing .....
my question is ..... does this vent require a hose or pipe that prevents heated oil or overflow from occurring?????????
Not sure if I should take it for service department to find out where the oil is venting from.
Or parts dept to replace missing hose or pipe IF there is one missing from my axle assembly.
Thanks
Cappy on an island surrounded by sharks 🦈.......
Old Mar 23, 2019 | 11:46 AM
Aloha, Cappy !!
95 MERC has a vent hose attached to the top of the axle housing, on the driver's side.
If you can get the car on a lift, it is easily visible -- and fixable -- for cheap.
Try an independent garage -- the dealer will rock your bank account ;>)
Old Mar 27, 2019 | 03:37 AM
Okay �� thanks 95 Mercury......
Cappy
Cold steel 75
Feb 6, 2020 09:30 AM
Stuartm77
Oct 12, 2018 06:48 AM
Chevelle505
Jun 23, 2010 07:36 PM
Baston-Rob
May 19, 2010 01:12 AM
slymer
Aug 30, 2009 08:54 PM
