Tachometer?
Old Jun 11, 2012 | 09:35 PM
MrThinroyy's Avatar
Default Tachometer?
So I'm looking into getting a 1996 Mercury Grand Marquis, but one of my biggest pet peeves is not having the RPM meter. It's not a huge deal, but I was wondering if anyone had any ideas where I could order one from, whether it's an entirely new cluster or just a gauge I can put on top of the dash/attached to the A strut inbetween the windshield and driver's side window. No promises on getting it, but I'm looking at Cougars and Grand Marquises so I'll need some advice either way.
Thanks,
MT.
Old Jun 12, 2012 | 07:02 PM
91GrandMarquisGT's Avatar
I dont think any that old came with a tach, maybe a Crown Vic had an option for it. Might just have to get a little 1 and mount it up somewhere.
Old Jun 13, 2012 | 05:50 AM
MrThinroyy's Avatar
No, there's no stock tach in the cluster, which is why I'm asking. Maybe there was a special ultra-luxury version that I could get one out of at a junk yard, OR (and this is what I'm leaning towards more) if there were any good, not too-expensive aftermarket ones I could get and install on the A-strut and run a wire to a tach box, if they have them
Old Jun 13, 2012 | 03:46 PM
I know there isnt a factory tach. Im saying maybe a Crown Vic has 1. A ultra luxury version would be a Lincoln Town Car. There is a spot to hook the tach to as its a 4.6L and they have coil packs. You would have to google where to hook it up too.
Old Jun 27, 2012 | 08:54 PM
pivichot's Avatar
Get a sunpro Tach from your local Advance or Autozone. They cost at max 40 dollars. May take two hours to install if you want a clean install. Did it on my 92. Make sure it doesn't block your instrument cluster.
Old Jul 25, 2012 | 02:25 AM
TrentMassey's Avatar
Old Jul 27, 2012 | 10:43 AM
BFM70's Avatar
It's unlikely you will find a dash pod with a factory tach. To install an aftermarket tach into any distributorless ignition system you need a tach adapter like this one:
http://www.jegs.com/p/Auto-Meter/Aut...50938/10002/-1
Once you have the adapter it's a simple three wire hookup that takes about 15 minutes to install
Old Feb 29, 2020 | 03:14 PM
dwyczalek's Avatar
The aftermarket tach you can get for about 30 to 40 dollars BUT you need a tach adapter that runs OVER 100 dollars not worth the conversion.
Old Mar 1, 2020 | 10:34 AM
  #9
Not SURE that it's swappable, but an instrument cluster from a Marauder has a proper (0-7,000 RPM) tach.
E-bay has one today (3/1/20) for 100 bucks.
Most aftermarket tachs go to 8,000 rpms, which is SILLY for a Grand Marquis -- your mildly-modified engine will never see 6,000 rpms.
The 2003 - 2004 Marauder instrument cluster SHOULD BE swappable, if you can find one.
Good luck !!
Custom Dual Exhaust Exits; Superior Tips
ProSport
Feb 23, 2014 07:36 AM
speedyred
Jul 12, 2012 09:51 PM
MrThinroyy
Jul 5, 2012 01:20 PM
speedyred
Aug 29, 2011 01:09 PM
Penniman
Oct 2, 2010 07:59 PM
