06 Premier 4.6 L Oil Temp sensor wiring problem
Old Oct 10, 2023 | 05:51 AM
fixmiester's Avatar
Default 06 Premier 4.6 L Oil Temp sensor wiring problem
Have wiring diagrams that show how the sensor connects to the PCM (gives pin numbers), but I don't have anything that shows the pin arrangement in the three plugs that connect to the PCM, so I can't ohm out the wiring harness to see if I have continuity leading to the oil temp sensor. Does anyone have info that correlates the pin numbers to the cable plugs connecting to the PCM? My schematics show wire colors, but I haven't seen the colors I'm looking for, so far. Would really appreciate any info you might have.
ffas23
Mar 30, 2023 02:36 PM
BilalMGM
May 21, 2012 09:14 PM
pokermike123
Apr 5, 2011 10:06 AM
northms
Sep 29, 2010 03:23 PM
tinman
Nov 11, 2008 11:55 AM
