2002 noisy rear end
hi i have just bought a 2002 mountaineer and discovered a droning noise from the rear end, i have been told this is a common problem and wondered if anyone could tell me how to fix this, also what will happen if i just live with it??
The Noise Is Comming From Your Rear Differential. Pretty Common On Most Ford LM SUV's. If You Have An Extended Service Plan It Should Cover It. If Not, Ask Your Servicing Dealer If They Can Offer An "AWA" (After Warranty Assistance). Provided The Vehicle Is Under 60,000 Miles And You Have A Good Repore With Them They Shouldnt Have A Problem. You May Be Asked To Pay A Deductable Towards The Repair, But Its Usually Under $200.00. Hope This Helps.
As For Your Question Lee, You Can Live With The Noise For A While But It Will Cause Further Damage In The Long Run. The Noise Your Hearing Is Comming From The Differential Carrier Bearings. They Need To Be Replaced. This Involves A Complete Overhaul Of The Unit. If You Guys Prefer, They Make A Kit That Runs Around $275.00 That You Can Purchase And Have Your Own Mechanic Repair It. Total Repair Time Is Less That 1 Day. Again Hope This Helps.
Edited by: LM_ServiceAdv
Thanks
Toyota made a big mistake putting the Toy 8" rear end, originally designed for the early mini trucks under the FJ with a big v6, 240 hp, and a MUCH heavier vehicle w/ a rear locker. Why they didnt use the 9.5 diff found under FJ80s is beyond me. Toyota has been cutting way too many corners with their 4x4s these days.
2002, 2006, back, differental, differential, end, mariner, mercery, mercury, mountaineer, noise, noisy, nose, rear, squeak
