Block Heater
Old Nov 29, 2007 | 02:59 PM
cam the man's Avatar
How do I install a block heater in my 93 Sable?
Old Dec 3, 2007 | 07:46 PM
frankinman's Avatar
im assuming that you want to install a coolant block heater not an oil heater...from my experience with my 3.8L engine i had to drain the coolant... remove e freeze plug (expansion plug) and installed an after market heater...(most have a rubber plug with a center bolt)...of course you should check tat you choose a freeze plug that is easiest to get to..also one that will not allow the cord on the heater to get entangled into belts ,pullys. or onto hot exhaust...once you push the heater into the freeze plug hole tighten the center bolt and fill the block with coolant...always check for leaks..hope this helps
bord141
Jan 1, 2009 12:47 PM
blake67
Oct 17, 2008 06:49 PM
cam the man
Jan 17, 2008 11:34 PM
elementx440
Dec 9, 2006 11:04 PM
Vanilla
Jul 25, 2005 08:51 PM
