Mercury Mystique-hesitation
Old Sep 20, 2005 | 10:34 PM
Melissa B.'s Avatar
Hello there,
I am new to this website. I have a 2000 Mercury Mystique, and unfortunately I am having serious problems with it since last Friday. [img]smileys/smiley19.gif[/img]My car has began to hesitate/bog down upon acceleration, and I can't put my finger on what is wrong, and neither can my mechanic. It has almost caused me to get into accidents due to it stalling upon climbing hills, and today it has been hestitating extremely bad to the point it has died and took over 3 times of engaging the ignition before it would turn over. At first I thought I had gotten bad gas, but I do not that is the case. When it was put on a computer diagnostic scanner, no codes came up, and unfortunately the car runs top notch when I take it to the mechanic. I have been on several websites, and apparently I am not the only one having this same problem with the Mystique, years 98"-00". Others have changed their air filters, spark plugs, oil filters, fuel filters, distributor caps, transmissions, fuel pumps, had their transmissions flushed and fuel injectors cleaned, etc., but have had not luck with this problem. Nothing came up on their diagnostic scans neither. All of these cars have milege from 93,000-115,000 on them. I do not know what to do! The only thing I have done so far was cleaned the Mass Air Flow sensor and put fuel injector cleaner/HEAT into my gas, but no results. I do not have the money to replace eveything like the others have, and not have it fix the problem! Anyone else experiencing the same thing or have and suggestions? PLEASE HELP! The bad thing is that I just paid my car off in February, and my extended warranty is expired!
Thanks!
Old Sep 23, 2005 | 07:33 PM
Patrick's Avatar
Administrator
go to an exhaust shop and have them check the catalytic convertor
Old Sep 24, 2005 | 04:42 PM
Melissa B.'s Avatar
I'm pretty sure that it is not the catalyic converter, because we have noticed my car hesitates/ stalls onlyonce it reaches under a quarter tank of gas. It runs excellent if it is above 1/2 tank.
Old Sep 27, 2005 | 04:58 PM
Lenny's Avatar
check out http://www.fordcontour.org
ask terry haines,he is the engineer that designed the contours/mystiques also the owner of haines motorsports.Edited by: Lenny
Old Sep 27, 2005 | 06:32 PM
Patrick's Avatar
Administrator
perhaps your gauge is wrong, and youre running out of gas??
Old Sep 27, 2005 | 09:37 PM
Melissa B.'s Avatar
[img]smileys/smiley1.gif[/img] Thank you for all of the suggestions! My check engine light is now on so hopefully a code will come up on the diagnostic. I will have my gas gauge checked also.
Old Oct 3, 2005 | 10:19 PM
Patrick's Avatar
Administrator
let us know what you find out! [img]smileys/smiley10.gif[/img]
crazycars
Feb 15, 2008 12:00 PM
Linky
Jun 27, 2006 11:33 PM
tigerfan31
Apr 19, 2006 09:33 AM
ima72
Apr 9, 2006 11:33 AM
tigerfan31
Mar 28, 2005 06:18 PM
