1999 Sable LS Rough Idle at Times
I''m new here and looking for some advice. I just bought a 1999 Sable LS with the Duratec engine. I have noticed that at certain times, not all the time, when I am stopped at a light the car begins to idle rough. Also, when I start to accelerate, i get some hesitation. Like I said it is not all the time, but it does happen more than I care for it to.
I have checked the air filter and it appears clean. I also added Slick 50 fuel system cleaner. The only thing I have not checked yet is the fuel filter.
Does anyone have any ideas on what this may be?
Thanks
Thanks
Vacuum leaks can cause this sort of thing as well as a dirty Idle Air control valve... Fuel filter would probably be a good place to start, they''re cheap and it probably is due for one anyhow if you don;t know when it''s been changed last....There were also some issue with the mass airflow sensor but these will USUALLY set off the check engine light...
Now to blast you with questions. How many miles does it have? Has it been tuned up ever? IS the check engine light on?
You''''ll have to have acode reader or scan toolto get the trouble codes to see why the light is on... Autozone and Advance used to do this for free..Or there are some inexpensive code readers out there in the $50 range (Probably about what most shops will charge to do this)... These will work on all 1996 and newer cars... It would probably be best to start with why the light is on... It could be any number of things that may or may not be related to your problem....
Manufacturer usually specifies for a tune up around 100K.. Tune up consists of at least new spark plugs, wires, fuel and air filter.. Some makes/models have other things to be done (egr or Idle air motor cleaned) but that''''s the basic...Edited by: maxfax3
I have the same sable as u, 99 ls.
Mine does the same thing, hesitates after accelerating from a stop, or randomly while driving low speeds. I was wondering the same thing as you. Let me know what it turns out to be for you.
It may need new plugs as well. I think my MGM is finally in need of new plugs. maybe even a top end tune up. I have just over 105k miles on it.
top end tuen up usually consists of plugs/wires/rotor/distributor cap/coil/capacitor (pick the parts that apply to your vehicle) and sometimes Oxygen sensors and the intake air flow sensors.
I think I''ll check mine this weekend since the weather looks like it will cooperate.
I brought the car into Autozone and had them check the engine light. The guy told me it was for a misfire in piston #2. He said it could be a bad plug or a dirty plug. Advised me to add some of the new concentrated gumout fuel injector cleaner and add fill up with 93 octane. Give 2-3 days and should be fine. I did what he said and I am on day 3 and the car is still the same. BTW - I noticed when I gun it, right before it kicks in I hear a "click" noise or a "knock" that sounds like it is from the engine. Then the car speeds up.
Any help is appreciated
