95 Mercury Sable Heater line adaptors
Old Jan 22, 2011 | 08:37 PM
Kojack's Avatar
Default 95 Mercury Sable Heater line adaptors
ok, so while doing a quick inspection on why the heat inside the car was weakening, i looked underneath the hood and saw antifreeze splashed up on the air filter housing and the air hose itself. recently, i did some extensive cleaning on the heater core lines and heater core itself as well and had good heat coming out, but after seeing the splashing, i knew the line protruding from the engine block was the culprit.
my question is, since this nipple (that was severely rusted away and rotted out) i took out simply slid right out of the hole; do the nipple adaptors screw into the holes or do they need to be welded into place? i measured what was left of the old line to be roughly 11/16 of an inch, but the new ones i bought and tried:
5/8 was too small in the hole
1/2 and 3/4 was too big
i need some help figuring this out.
Old Feb 3, 2011 | 02:20 AM
alex67's Avatar
I would suggest you to take help from a good technician.he will be the right person to help you out.
Old Feb 16, 2011 | 08:35 PM
kghow2000's Avatar
what about pressure fittings.flare out the ends of the hose you have and make it work.
Old Mar 10, 2011 | 03:00 AM
jackgem's Avatar
Do the nipple adaptors screw into the holes or do they need to be welded into place? i measured what was left of the old line to be roughly 11/16 of an inch, but the new ones i bought and tried..
cobrahd1999
Nov 28, 2012 04:54 PM
merry
Jan 4, 2009 11:14 PM
thebestpharma
Dec 28, 2008 02:58 PM
88Tracer
Jan 18, 2008 08:21 PM
swwatch
Aug 17, 2007 10:27 AM
