96 sable wont start on first try
Old Apr 10, 2009 | 02:34 PM
trow56's Avatar
Default 96 sable wont start on first try
my sable will not start on the first try it takes two or three times of turning the key before it will start any thoughts ?
Old Apr 10, 2009 | 05:53 PM
maxfax3's Avatar
Sorry to bomb you with questions but we'll need some more info..
Which engine (Duratec DOHC or Vulcan OHV) and how many miles?
Hows the state of tune? (Plugs, wires, fuel filter, air filter?) IS the check engine light on? Have you ever had the Idle Air Control valve cleaned or replaced?
Old Apr 10, 2009 | 08:25 PM
trow56's Avatar
It has a Duratec 3.0 260,000miles, the pluges and wires were changed 2 years ago check engine light is not on. I have not done anythiing to the Idle air control
Old Apr 10, 2009 | 10:28 PM
probably need to clean the idle air control valve and check the ignition coil(s) to make sure they're still good. I just cleaned the IAC on my car and it sorted the starting issues I was having.
Old Apr 10, 2009 | 11:30 PM
conan312's Avatar
How long has this problem been going on? Did it just start doing it? If so, what was it like before?
Old Apr 11, 2009 | 12:08 AM
maxfax3's Avatar
A new fuel filter may not hurt anything regardless.. Fuel quality is taking a nose dive.. Because there is such a surplus right now (even though prices at the pumps don;t reflect this) the gas has been sitting around and being transported between several storage tanks more than it normally was back before this past summer..
I've been having alot of customers lately with complaints of their fuel milage being lower than usual.. After smelling the gas in a few of those cars it wasn;t hard to determine why...
Old Apr 11, 2009 | 06:35 AM
conan312's Avatar
I 100% agree with Max. A fuel filter is the perfect place to start with your symptoms. That is if you have not already done so.
Old Apr 11, 2009 | 10:40 AM
trow56's Avatar
thanks for the info
hparies
Aug 17, 2010 06:00 AM
2002cougarv6
Feb 21, 2010 01:56 PM
crazyrog17
Jan 31, 2010 01:09 PM
srm12711
Jun 10, 2009 09:00 PM
tuxpan7x7
Oct 23, 2006 01:29 AM
