96 Sabre Power Steering Leak when parked
Old Oct 27, 2008 | 12:17 PM
qjc000's Avatar
96 Sable, 87k miles, recent power steering pump replacement.
When I drive it during the week to work, I get no overnight fluid leakage. When it is parked over the weekend, I get some drips after a day. Over filled? Leak coming from under carriage mid between wheels close to transmission cover. Could this be trans fluid?
Thanks!
Old Oct 29, 2008 | 09:53 PM
conan312's Avatar
Could one of the hoses be leaking and running fluid away from the leak? How is the trans fluid level? How much is it leaking? Let me know. Later.
Old Oct 31, 2008 | 09:12 AM
qjc000's Avatar
I need to check the fluid levels, yes. It was a 2" diameter spot.
Old Nov 4, 2008 | 08:37 PM
conan312's Avatar
Power steering fluid usually leaks when the car is running and the pump and rack are pressurized. Just keep an eye on fluid levels and will get your answer if you can''t find the source of the leak. Good luck.
fastframebelair
Sep 27, 2013 01:40 AM
hdy443
Nov 25, 2010 10:49 PM
leapin
Jul 3, 2007 06:35 PM
paniro187
Jun 18, 2007 10:34 PM
paulhanh
May 13, 2006 01:06 PM
