High rev
Old May 19, 2008 | 09:32 AM
headviking's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
Hi all. This is my first post on thie forum. I hope I can get some help here. My wife has a 1999 sable with the high output engine. Recently whenever she starts the car the engine seems to rev above 1600 RPM, then after a couple of minutes will drop down to aroud the 700 RPM. Is this the work of some sort of censor or what&gt;
Old May 20, 2008 | 10:39 PM
RickMN's Avatar
It could be a few things:
1) Vacuum leak when cold that stops when the engine is heated up.
2) Bad or dirty Idle Air Control valve (common problem on these vehicles).
3) Carboned up throttle body.
4) Bad engine coolant temp sensor or air temp sensor.
What's the gas mileage like? If the mileage is bad, I'd head right for the vacuum leak or the sensors.
Old May 21, 2008 | 02:06 AM
headviking's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
thanks I'll look into that.
A_T_P
Jun 1, 2012 03:04 PM
2001GTTT
Mar 7, 2011 05:17 AM
AngelD
Oct 20, 2006 01:15 AM
dnwright
Aug 11, 2006 12:45 AM
hdvespa
Jul 26, 2006 01:22 PM
