My starter 2002 mercury sable
Old Aug 17, 2009 | 03:16 PM
Mcafee18's Avatar
Default My starter 2002 mercury sable
Now this car has had this problem for awhile now but both starter and flywheel have been replaced and it still seems the starter does not want to catch. When it misses you hear a loud WHEEEEEEEEEEEE sound and the car does not start. My friend told me it could be that the starter is pushed too far a certain way and most of the teeth are just mussing the flywheel all together. He also told me to put bushings on them so I called my local auto shop and was informed that putting bushings on a Ford product and impossible (The mechanic said they were only adaptable to GMC products). Now he is saying I can use washers which I don't want to do because it doesn't seem too safe.
If anyone can help me with this it would be greatly appreciated. Again both flywheel and starter are maybe a year old and there are no teeth missing from the flywheel *I checked at my work when I was under the car*.
Old Aug 17, 2009 | 04:24 PM
check the cables to make sure they are making good contact at the battery and the starter. It might be having a low voltage problem and just not throwing out all the way. You could have also gotten a starter (especially if it was rebuilt) that was not properly (re)built and the throw out gear is catching on the shaft. taking the starter off and greasing the shaft may help, but if there's a notch in it, you'll continue to have the problem.
Old Aug 20, 2009 | 01:05 AM
conan312's Avatar
You can try some starter shims.
davidlogan
Apr 23, 2011 11:55 AM
altlnuts
Dec 13, 2010 07:20 PM
wbsteele
Nov 26, 2008 11:37 PM
jscranton
Apr 18, 2006 06:37 PM
Triple_access
Dec 6, 2005 01:16 PM
