rear sway( stabilizer bar)
Old Apr 28, 2009 | 09:44 AM
coolfool's Avatar
Question rear sway( stabilizer bar)
hey all, i have to replace the bushings on my rear sway/ stabilizer bar and i dont know what the diameter of ithe bar is. it is a 1997 sable 3.0 liter with the 12 valve overhead. would anyone out there know off hand? thanks a lot, greatly appreciated
Old Apr 28, 2009 | 04:49 PM
maxfax3's Avatar
Your best bet would be to get you hands on a set of calipers and measure it.. It is possible that the size could differ from car to car...
Old Apr 28, 2009 | 06:05 PM
wow... my cars are way older and I'm just barely looking at replacing the sway bar links... the bushings are fine... though maybe a little cracked around the edges... they're still doing their job.
anyhow... it should be 18, 19, or 20 mm. 23/32", 3/4", 25/32"
a caliper for measuring round objects would be your best bet to figure out which one it is since it seems they used 3 different ones that year.
Old Apr 29, 2009 | 09:28 PM
maxfax3's Avatar
WOW not much difference between those.. Those specs ought to make it easier to figure it out though...
Old Apr 29, 2009 | 10:19 PM
not much difference until you try to put the wrong size bushing on... if it's not right, you'll have hell trying to get it to work. it's amazing what one mm difference will do.
ronnjonn
May 8, 2012 12:18 PM
01red
May 13, 2011 11:03 PM
yonderfishin
Apr 23, 2011 02:54 PM
duckstu
Sep 23, 2008 11:23 AM
vinny98marquis
Jul 8, 2008 01:54 PM
