Rear window/outside mirror defrost
Old Feb 21, 2009 | 07:44 PM
koen's Avatar
My 2003 Sable''''''''s rear window defrost & outside mirror defrost are not working.
1. The light is turned on once the defrost switch on the IP is pressed.
2. I canhear the clicking noise from the relay on the dash when the defrost swith is pressed.
3. All the relays and fuses are checked and they are fine. The grid on the rear window is also checked and they are all connected well.
Now what? Why is this kind of mulfunction happening to a poor guy like me?[img]smileys/smiley19.gif[/img]Edited by: koen
Old Feb 21, 2009 | 08:22 PM
koen's Avatar
I just found the connecting part (tab) on the left side of the rear window is detached from the window. Can I just glue it with some conductive glue?
1. Is it possible that my outside mirror defrosting is not working because of the detached connection on the rear window?
2. Has anyone attached this using a quick fix repair kit, not a soldering fix? I heard soldering might break the glass.Edited by: koen
Old Feb 22, 2009 | 02:52 PM
maxfax3's Avatar
IT is possible the broken connection at the window is keeping everything from powering on... Some of the rear defrost timers rely on a certain amp draw.. IF it isn;t there at all or there is too much it will not kick on..
The regular conductive glue would probably be your best bet to re attach the terminal on the window.. I''ve had mixed results with the stuff (sometimes it lets loose in hot weather) But definitely don;t try the solder the thing.. The window will go pop real quick like... IF you have a test light see if you get power to one of the terminals to the rear window..
Old Feb 23, 2009 | 06:34 PM
conan312's Avatar
I agree w/the non-solder method. As for the heated rear mirrors, mine are always operating. I think they are heated year round at a low temp cause I know mine work without the rear defroster on. Even does away with early morning summmer dew. Then again mine is a ''97. Did they stop working at the same time?
HLT
May 1, 2009 08:30 AM
rcupak
Mar 22, 2009 03:59 PM
89marq
Jan 17, 2008 05:48 PM
sargej1
Mar 30, 2007 07:27 PM
bvkirk
Aug 23, 2006 11:28 PM
