Strange light flashes on then off
Old Jun 28, 2009 | 10:52 PM
AndrewSmith's Avatar
Default Strange light flashes on then off
Hi, there:
I have a 2001 Sable. Recently, I found a strange phenomenon. When I turned on the fan and lower the temperature for a while, the lights for "ABS" "Brake" and "Water pump" turn on. Then after I turned off the fan, the lights gradually turned off. What could be the possible reason?
Thanks
Andy
Old Jun 29, 2009 | 05:46 AM
conan312's Avatar
Sounds like a short or bad ground. Do all those things seem to be working properly?
Old Jun 29, 2009 | 11:27 AM
Hi, there:
Thanks for the reply. The ABS and brake seem to work properly. The water pump doesn't seem to be bad, otherwise the engine will overheat. Is there any way for locate the bad grounding point?
Thanks
Andy
Old Jul 3, 2009 | 09:08 PM
conan312's Avatar
So it is not when you turn the fan on, it's when you turn the temp down "for awhile?".
Old Jul 4, 2009 | 05:22 PM
makes me think there is a voltage regulation issue. it's like the battery is dropping a cell for a while or the alternator is dropping out.
check the battery cables to make sure they're not loose or corroded and check the cables on the alternator for the same thing.
GARMASTERS
Jul 28, 2015 01:43 PM
Limoguy
May 20, 2013 06:22 PM
jason sereiko
Jun 20, 2008 09:04 PM
eubank
Jul 24, 2007 10:27 AM
MN250R1
Jul 16, 2005 11:45 PM
