windshield washer
Old May 13, 2008 | 08:02 PM
1996  green sab's Avatar
windshield washer doesn't squirt water, resevoir is full, need to know how to check pump or fuse.
Old May 13, 2008 | 11:51 PM
conan312's Avatar
First, listen for pump noise w/the car off. More than likely you won't hear anything so check your manual or the back of the fuse box cover and see if there is a fuse for that. Is there something else that doesn't work? Usually a fuse controls more than one thing. The easiest thing to do is see if there is power at the pump. Use a check light, multi-meter or what have you. You can even run a couple of wires from the battery straight to the pump and see if spins. Let me know. Usually when they go, they go. Cheap and easy to replace.
GS37
Jul 14, 2015 02:44 PM
stonegatehts11
Jan 27, 2013 07:29 AM
mobbdeep
Jan 10, 2009 11:31 AM
1996 green sab
Aug 13, 2008 12:56 PM
92Mercury
Nov 8, 2007 08:06 PM
