96 Mercury sable Overheating
Old Jul 10, 2005 | 06:45 PM
marco's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
96 mercury sable V6 24 valves DHOC station wagon i have problems of overheating in the mornings water is under level i fill it up and in aprox. 10 min it's start heating over the temperature level. yesterday they gave it a service clean the radiator and motor chance the thermostate to 180 and did the same a while after that the ventilators are fine doing their work when it starts overheating what can it be the problem?
this is the motor of the car,,, big mothor..[img]uploads/marco/6CABE_Fotos_Cunple_Marco_01220000.jpg[/img]
Old Jul 15, 2005 | 11:42 AM
Vanilla's Avatar
I too have had problems with overheating on my 96 Sable. One thing to try is once the engine is heated up turn on the heater in the car, full blast, if it seems to get rather cool after a bit the water pump is probably toasted. That was my situation, but it's apparently not the only problem with my car.
I hope that helps.
-Jeff
Old Jul 16, 2005 | 09:57 AM
Do a compression check. Sounds like possible leakdown on head gasket(s)
ireadrules
Aug 13, 2007 07:39 AM
sinned
Aug 10, 2006 06:43 PM
bgraves
Jul 1, 2006 12:20 PM
frank664
Nov 9, 2005 03:46 PM
Vanilla
Nov 9, 2005 03:43 PM
