DRIVER WINDOW
Old Jul 14, 2007 | 12:21 PM
JT2000's Avatar
My driver side window doesn't roll down but my passebger one does. I replaced the switch but it didn't fix the problem. Anyone have any ideas? thanks
Old Jul 26, 2007 | 12:27 PM
danielhaumann06's Avatar
What year is your car? I would guess you need a new motor for you window. The one on this site is for a 99 cougar and its only like $35. http://www.carpartswholesale.com/cpw....php?make_text =mercury&ml=coug--012&model_text=cougar&year=199 9&part_name=window_motor&brand_name=a1_car done&s =1&my=1&repcat=true
Old Aug 31, 2007 | 10:59 AM
lowrevs's Avatar
In other research I've done on other forums I've found that they say there's a relay in the drivers door near the speaker which will cause this. I have the problem now with a twist. The drivers window won't go up or down but the passenger window will only go up on the passenger switch but will go up or down with the driver switch. Go figure. It would be nice to find a single solution. Relay sounds logical, I guess. BTW, I have a 2000 Cougar 2.5L V6
Old Sep 20, 2007 | 12:02 AM
cougarowner's Avatar
hm..sounds almost like the problems my Cougar has...except my passenger side's screwed up. sometimes i have to push the button a few times to get the passenger window to roll down. and when i roll it up, it works best with the passenger side button instead of the driver's side button. but yeah, what i'm goin to do is check my wires see if they need replaced and then check my relay...if none of those does it then it has to be the motor...so, i'd say try checking your wires/wire connections, and see if that's the problem.
DaleM
May 21, 2012 02:59 PM
63sxxl
Dec 5, 2011 06:42 AM
petemanj
Oct 9, 2010 12:10 AM
TrishMustang
Jun 28, 2009 06:17 AM
koen
Feb 23, 2009 01:28 PM
