1966 mercury reverse lights
Old Oct 21, 2010 | 09:12 PM
raptor's Avatar
Default 1966 mercury reverse lights
anyone have any suggestions as to how i may be able to fix my reverse lights on my 1966 monterey? i took everything apart to paint, put back together and now they dont work.....
Old Oct 21, 2010 | 10:28 PM
Bulldozer's Avatar
I'm not sure what you mean by took everything apart, the whole car, or the area around the back up lights.
First thing I would do is check the fuse.
Then see if you have power to the lights plug in.
If you have power to the lights plug in, then it has to be between there and the lights. How are the light bulb sockets, and a remote possibility, the bulbs themselves.
Then see if you have power to the neutral/reverse switch.
If you have power to the Neutral/reverse switch, pull the plug on the switch & use a jumper wire to jump the 2 plug contacts together.
If they now work, you either have a bad neutral/reverse switch or its out of adjustment with the shift linkage.
Clem314
Aug 3, 2021 05:41 PM
elroy6468
May 3, 2015 11:14 AM
bzaw
Feb 3, 2009 05:33 PM
numberonepugs
Dec 16, 2008 02:56 PM
Jasonlee32
Sep 25, 2007 03:04 PM
