2002 Outside Temp Problem
Old Jul 27, 2011 | 04:43 PM
Tommy Rodder's Avatar
Default 2002 Outside Temp Problem
Have the automatic air & the outside temp reading stays at 127 degrees all the time, no matter the outside temp. Is this an indication that the outside temperature sensor has gone bad? Where is it located (assume in front of radiator) and is there an ohm meter reading to test it? The A/C works but I have to crank the temp all the way to the max to get it to throw heat. Seems that it is sensing the outside temp and deciding it doesn't need heat until I max it out.
Thanks for all your help.
Tom
Krollmonster
Mar 15, 2010 07:54 PM
mrmadhead
Aug 4, 2009 11:42 AM
HLT
May 1, 2009 08:30 AM
koen
Feb 23, 2009 06:34 PM
sargej1
Mar 30, 2007 07:27 PM
