High Performance Brake Fluid
Old Feb 9, 2020 | 01:56 PM
Default High Performance Brake Fluid
For those of you that demand optimum performance from your vehicle's braking system, there is a new Brake Fluid type that should interest you.
Made by Bosch, the new fluid designation is ESI6-32N -- replaces and is compatible with: DOT 3; DOT 4; and DOT 5.1.
The new fluid has a lower viscosity, which allows for better functioning of anti-lock brake systems, plus the added bonus of longer service life. Fluid life is double that of the standard DOT 3 fluid.
Dry Boiling Point = 270 C. - 518 F.
Wet Boiling Point = 185 C. - 365 F.
Comes in a 32-OZ metal CAN -- available at O'Reilly's and Amazon.com.
Eclipse Calipers; Motorcraft Police Pads; ACDelco Drilled&Slotted Rotors; ESI6-32N Brake Fluid; Centric Hoses.
dnohe
Aug 4, 2018 02:06 PM
stangcbr
May 15, 2010 10:37 PM
JOSEPH SCOPELLI
Dec 27, 2008 10:44 PM
Izzy
Nov 24, 2008 12:47 AM
sharpshooter677
Oct 11, 2007 06:30 PM
