Need Help.
Old Dec 12, 2008 | 12:14 PM
apple2005's Avatar
I bought a used Grand Marquis LS 1997 used car Made in Canada. It is fully automatic with digital odometer. It is run 285000 km. I found that it is showing in yellow" check engine" and in green "check air suspension".
What does that mean and what to do?
I shall be thankful to you.
Old Dec 12, 2008 | 02:31 PM
Mer.Gra.Mar's Avatar
Old Dec 12, 2008 | 04:40 PM
check engine means there''s a problem with one of the sensors or the sensor readings in the engine. if you can find out what the code is that the engine computer has, then we can narrow it down.
The air suspension may have the same thing. or it could be turned off. Download the manual and check it out to see where that switch is and make sure the system is on. if it is already on, then you may have to service it.
Old Dec 13, 2008 | 06:15 PM
Shonlo503's Avatar
the check engine light can be numerous different things from dpfe sensors to egr to seat belt sensors. Check it out and let me know, I will check out the professional technician society''s website and let you know what the code is. As far as the air bag suspension.. check in the trunk. there should be a switch on the driver side. If its off, turn it on.. if its on.. and you still have a problem... then there might be something wrong with the solenoids. Let me know.. Ill check it out for you
Old Dec 14, 2008 | 09:51 AM
apple2005's Avatar
Originally Posted by slymer
check engine means there''''''''s a problem with one of the sensors or the sensor readings in the engine. if you can find out what the code is that the engine computer has, then we can narrow it down.
QUOTE=Shonlo503]the check engine light can be numerous different things
know, I will check out the professional technician society''''''''s website
Ill check it out for you.
Thanks slymer and shonlo503 for your support.
This is the first time I am using automatic Murcury Grand Marquis. I don''''t know the code. Also the authorised dealer of this type of cars is away from me.. It will take some time for me to go to that place.
I shall be thankful if you tell me an easy way if I can fix anything here. What maintenance do I need? etc etc.
Edited by: apple2005
Old Dec 14, 2008 | 10:50 AM
usually a parts store will have code readers that can give you the codes. but that''s here in the USA. dunno about SA.
troycowanmp
Aug 16, 2012 10:00 PM
flavor4real
Oct 3, 2007 10:28 AM
mybeast87
Jul 30, 2006 08:30 PM
amanda129
Mar 8, 2005 10:57 PM
Higgy
Feb 6, 2005 03:13 AM
