No Heat No AC But plenty of air.
Old Feb 17, 2008 | 02:04 PM
  #11
86VickyLX's Avatar
You have R12.
I agree with 87_Crown_Vic
it might be a blend door problem.
It could also be something to do with Automatic Climate Controls. Jadman, do you know if you have Automatic Climate Control?
To tell, you'll have numbers on your heater controls. Actually it should say if it is Automatic Climate control. I have been told countless times that they have problems too.
Old Feb 20, 2008 | 04:30 PM
  #12
Jadman's Avatar
No I don't have the climate controls. Just the good ol slider, red and blue. I am hoping that this helps in taking the dash off.
When and if I ever get the rear door windows working.
This car is too much!
Old Feb 20, 2008 | 04:57 PM
  #13
a simple fix is to reach under the dash and disconnect the vacuum servo under/behind glovebox. plug the line with a small screw or something which lets the heat go full bore. it could be the thermostat is stuck somewhat opened also.
Old Feb 27, 2008 | 09:53 PM
  #14
86VickyLX's Avatar
If it was the thermostat, it would eventually warm up. I bet the core is clogged.
Old Jan 27, 2011 | 07:56 PM
  #15
Mil1ion's Avatar
Yes Old thread.
However
Tne 92-94 MGM,CV, and TC all have 12 volt actuator motors.. NOT Vacuum
The dc motor is operated by the ATC control switching polarity causing the DC Motor or move one way or the other.
If replacing, make very sure you order the CORRECT Part
jinroh
Apr 14, 2007 11:38 AM
mishalah
Nov 7, 2006 07:50 AM
mishalah
Oct 21, 2006 12:31 AM
haroundb
Feb 20, 2005 12:14 AM
haroundb
Nov 8, 2004 07:08 PM
