Weird problem with map lights, or reading lights.
Old Oct 16, 2020 | 10:32 AM
ELLCAPITAN's Avatar
Default Weird problem with map lights, or reading lights.
'05 GMq LX. What happens is, the map lights will sometimes--actually, most of the time--only work as dome lights, meaning they both turn on when a door is opened or unlocked (or by the dimmer switch). In their failed state, the map light buttons will NOT turn the lights on when they're off, but they WILL turn the respective lights off when they're on (i.e. if a door is open, etc). And like I said, other times they work just fine, but more often than not, when I need a map light, the buttons won't turn them on. Annoying. Does anyone know what's up here?
Old Jan 16, 2022 | 12:55 PM
sylentnite's Avatar
Did you ever find out the issue, I am having the same problem with my car?
Old Jan 16, 2022 | 03:27 PM
ELLCAPITAN's Avatar
Well, I thought I fixed it. The trunk lid wiring was detached from the left side hinge gooseneck. I zip tied it back and thought problem went away for a while, but eventually came back.. Sorry, no updates, I couldn't find any more info and just gave up for the time being. Learned to live without.
Old Jan 18, 2022 | 01:56 PM
sylentnite's Avatar
I gotcha, it's got to be a connector or something, I hit a bump one time and it started working, next time I got back in the car it was back to not working. My sun visor lights aren't working also. 03 marauder
Old Jan 18, 2022 | 04:21 PM
ELLCAPITAN's Avatar
I still think, at least in my case, it's something inside the trunk lid. I'll get around to it one day. I'll update when I do.
Old Jan 11, 2023 | 05:10 PM
PaulPippenger's Avatar
Default Hi, i have a mercury marauder ,same issue
I am in the process of finding the problem , all connections are good in overhead console.
All other lights are good.i am going to replace the LCM on saturday 1/14/23 .
that test should help.
Peace
ELLCAPITAN
Oct 16, 2020 10:29 AM
Ranger121
Mar 27, 2014 04:36 PM
lowprorider
Feb 18, 2014 08:58 AM
2001GTTT
Mar 7, 2011 05:09 AM
PtotheK
Aug 14, 2006 02:40 AM
