Window issues
Old Nov 11, 2012 | 02:11 PM
ctnov's Avatar
Default Window issues
So far I've replaced two window regulators...Driver Rear and Passenger Front. I hear the motors working however the windows STILL do not go up and down. I tested the motors while disconnected from the regulator and the gears spin as they should...am I missing something?! Please help!
Old Nov 29, 2012 | 05:46 AM
sbills55's Avatar
Recheck installation ( make sure motor is in up postion) I sure yo did this
Old Nov 30, 2012 | 02:53 PM
ctnov's Avatar
It ended up being the plastic gears inside the motor. Instead of spending $100 on new gears, I rigged up something and now ALL my windows work!!
Old Dec 4, 2012 | 03:15 PM
sbills55's Avatar
That will do it........lol
Old Dec 10, 2012 | 04:02 AM
Florentinote's Avatar
Old Dec 14, 2012 | 07:01 AM
Albert077's Avatar
I don't think so the plastic gears are more long term useful so the metal gear is best in its not the matter that they are more expensive then the plastic. But here I think the gears are not the problem as the one member says above that its the fault of fixing the motors. Because sometime the motor installed on some very little distance and it stops the window. come on check the installation again and then find some other solutions.
Old Dec 14, 2012 | 09:34 AM
EddieE's Avatar
Buy a gear plug kit, contains the three hard plastic plugs that fit inside the motor, or make a three piece set out of steel poxy. Dorman Help! product # 74410, cost about six bucks. Be sure to re-lub the gears while you have it open. Careful taking motor out of regulator assembly, use plastic ties to hold it together while you fix the motor, if cable comes lose you will need a new window regulator.
ctnov
Jul 1, 2011 09:45 PM
JT2000
Sep 20, 2007 12:02 AM
srch4aresn
May 26, 2007 09:15 PM
Robyn
Jul 2, 2006 11:20 AM
jsouthse
Apr 15, 2005 11:28 AM
