Grinding Near Front Diff
Old 08-19-2007, 10:37 AM
SteveJco516's Avatar
When i drive it out i get a really bad grinding clanking noise that sounds like its comeing from near the front diff
I thought it was the exhaust got bent an was hitting the drive shaft from me bottoming out somewhere, but i checked that out an the shaft is spinning freely
any ideas as to what it could be ?
its a 1998
Old 07-25-2008, 02:17 PM
gravedigger15's Avatar
u did this post almost a year ago but if the problem is still occuring, i had the same thing on my 99 mountaineer. it turned out to be a bad bearing in the front diff and i had it replaced.
Old 08-20-2008, 11:17 PM
jason sereiko's Avatar
cv drive shaft or bearing. It is hard to tell unless you actually lookm at this one. you can try to repack the bearing if it is not sealed or crack it open and look at the bearing. it is one or the other
Old 08-20-2008, 11:19 PM
Gravedigger15, good memory. it is almost scary that you remember this from a year ago. Anyway, keep up the good work and welcome to the forum.
joeguzman10
04-24-2009 11:18 AM
pecos21
12-30-2008 05:57 AM
sgettin
02-25-2008 07:29 AM
battlecougar
10-17-2005 08:17 PM
Quick Reply: Grinding Near Front Diff
