1995 mystique-no fire
Old Sep 18, 2008 | 09:47 PM
larry stone's Avatar
I was driving on a rainy day, car runs fine then just stalls with no noises. I took it to a ford garage and they said they did not know what was wrong to try a icm. I changed that and the coil pack and still no start(fire). The car has 65000 miles and is a good car. I cannot find a manuel that tells me what I should check hot key on or hot at cranking. 480 dollars in parts and still trying-need help... It is a 2.5 engineEdited by: larry stone
Old Oct 5, 2008 | 12:46 AM
conan312's Avatar
If the engine just stalled out at speed without any warning or prior probs, I would try checking the crank sensor.
Old Oct 7, 2008 | 06:12 PM
Thank You very much. It was a bad connector at the sensor. I replaced the pins and the put it back and now runs fine. I now since have had the check engine light come on and when I unplug the air flow sensor on the air tube and it will run like new. I have tried to get a code check at a couple of places and they say their tester only goes back to 1996. I have taken that sensor out and cleaned the ends carefully with brake clean but no change.
Thanks Again,
Larry
Old Oct 8, 2008 | 02:34 AM
conan312's Avatar
Sounds like you just need to replace the MAF sensor now. Then reset the comp by taking off the the neg. battery terminal for a few mins. Let me know.
osmossis
Jan 17, 2008 06:58 PM
AutomaticCat
Aug 2, 2007 10:51 AM
4cbuck
Feb 22, 2007 09:21 PM
gibs107
Aug 14, 2006 02:43 AM
Coachkey22
Mar 21, 2006 08:49 PM
