89 sable gs heat gets warm not hot???
Old Jan 27, 2008 | 09:55 AM
truckin77's Avatar
hello everyone, new here.. I have a question, I have a 89 sable gs, 3.0L auto trans. the engine doesnt get very warm, the temp. gauge gets just off the cold mark and wont go any higher, not complaining too much bout that, but the heat doesnt get very warm, any ideas would be a great help. the climate controls are just the basic ***** nothing digital,
< =text/>
_uacct = "UA-939292-45";
urchinTracker();
Old Jan 27, 2008 | 11:55 AM
have you checked your coolnt level lately?
have you replaced any hoses that may be collapsed?
have you replaced your thermostat at any point?
have you ever flushed out the heater core backwards to clean it?
have ou ever drained coolant and added new stuff?
the coolant system on the Sable and Taurus is known for popping head gaskets if the coolant isnt changed on a regualr basis. should be changed out every 2 years or so. some of the questions above are some things to check for and replace if necessary. dont need the cooling system of your car causing bigger more costly problems.
Old Jan 27, 2008 | 05:10 PM
truckin77's Avatar
havent done any of those things.. my question is why doesnt the engine get very warm, the temp. gauge barely comes off the cold mark, should be almost half way up on the gauge.....
< =text/>
urchinTracker();
Old Jan 27, 2008 | 05:36 PM
Harvest Gold's Avatar
Almost sounds like your thermostat is stuck open. Same thing happened to my truck. Changed the thermostat, and all was better.
Old Jan 27, 2008 | 09:47 PM
if the thermostat doesnt close properly, it will let the coolant constantly flow thru and not let the engine warm the coolant and release it to the radiator to let in the cooler stuff.
Old Jan 28, 2008 | 02:42 PM
conan312's Avatar
Harvest Gold is on the right track. Only the original body style Taurus and Sables had head gasket troubles. Mostly the 3.8 litre, more than the 3.0, which was phased out when the new body style was introduced. Let your car run for a while and feel all the coolant hoses. They should all be close in temp. And especially feel the two heater hoses that enter the firewall on the passenger side. That will eliminate the heater core. If you're low on coolant, feel the passenger side rug under the floormat for wetness. That will be a heater core. Let me know.
Ty in Arizona
Oct 1, 2011 06:58 PM
kim1349
Sep 19, 2009 12:29 AM
pdman
Dec 11, 2008 07:54 AM
dmarietx
Sep 1, 2008 06:51 PM
moonscar119
Aug 30, 2006 12:14 PM
