engine light on
Old Jul 16, 2008 | 10:28 PM
jenlegs's Avatar
i have a 2001 sable and at lights and stops it hesitates and somtimes stalls. and the engine light is on and stays on all the time need help thanks
Old Jul 17, 2008 | 10:48 PM
jason sereiko's Avatar
you need the code read. go to a parts store and have them read it. autozone does it for free
Old Jul 18, 2008 | 08:58 PM
jenlegs's Avatar
We did take it to auto zone and they printed out the troubleshooting list and all it told us is that the EGR has detected too much flow on the EGR system....probable causes are...
1~EGR valve stuck open
2~failed EGR pressure sensor
3~failed EGR valve
4~failed EGR pressure sensor
5~failed EGR position sensor
Then the guy told us it COULD be the mass air flow, co2 sensor, the fuel injection,or the DPFE sensor....
Didn''t really help me much..This reading was done about a year ago and an auto mechanic told me it was no big deal and didn''t really need to be changed...just wondering if I should change the o2 sensor or is it something else that is wrong...with gas prices the way they are I don''t have tons of money to waste on something that isn''t wrong...so if anyone could shed some light on my problem that would be great. Thank you so much.[img]smileys/smiley1.gif[/img]
Edited by: jenlegs
Old Jul 19, 2008 | 12:34 PM
RogerB34's Avatar
You didn''t say engine or mileage. EGR valve operation is significant to engine performance. Controls combustion temp on hard acceleration and reduces NO on deceleration. Vulcan Motorcraft is $44 net plus S/H. Not a difficult DIY install.Anon Motorcraft valve began failing after 20k miles. Replaced with Motorcraft. Check to see that vacuum lines are intact esp around the EGR valve.
Old Jul 19, 2008 | 01:11 PM
If this is a old code, get it pulld and read again. the light being on and store up to 25 new codes. this might help if a new code popped up. No do not change the o2 sensor yet. I would change the egr sensor or atleast clean out the connection. pull the code again
Old Jul 22, 2008 | 06:55 PM
jenlegs's Avatar
its a 3.0 Dual overhead cam with about 80,000 miles on it.
Old Jul 30, 2008 | 12:06 AM
RogerB34's Avatar
Link to EGR operation and DTC:
http://www.tomco-inc.com/Tech_Tips/ttt35.pdf
Old Jul 30, 2008 | 06:45 AM
conan312's Avatar
If all 5 codes were related to the EGR (exhaust gas recirculation) valve then don''t let them sell you part after part ''til it''s fixed. Definatly pull the codes again. Let me know.
Old Jul 30, 2008 | 08:28 AM
  #9
I agree with conan312. The best thing to do is pull the code, all of them again.
Old Jul 31, 2008 | 02:28 AM
  #10
jenlegs's Avatar
Ok I will do that and let you know...Thanks
214shaft
Jan 3, 2011 11:21 PM
olds97_lss
Jul 6, 2008 02:12 PM
geri
Sep 5, 2007 05:14 PM
geri
Sep 4, 2007 08:18 PM
damercga
Dec 31, 2006 05:24 PM
