Horn not working
Old Dec 16, 2010 | 04:26 PM
teroot's Avatar
Default Horn not working
Have a 93 Sable and I can't get the horn to work. I did the two obvious repairs, replacing the fuse first (it wasn't blown but I did it anyway) and then I replaced the actual horn itself. Still no luck. The only things left would be the wiring or the switch on the steering wheel right? I was at the salvage yard the other day and removed the horn pad (which was connected to the airbag as well) from a car on the lot just to look at it, but I'm not sure I'd be comfortable doing that on my car. I have to assume the horn switch is in between the pad and the airbag. Is this something I am able to diagnose/replace without causing the airbag to blow up?
Old Dec 16, 2010 | 04:55 PM
Bulldozer's Avatar
Before you do that, have you checked the horn relay which should be in the engine compartment fuse box?
Old Dec 19, 2010 | 05:01 PM
teroot's Avatar
Thanks Bulldozer - I checked the engine compartment fuse box but the diagram in there said nothing about the horn (it didn't have any relays at all in there actually, just fuses), so I went back to the fuse box under the steering wheel and the horn relay was actually in there. Popped it out and I will have to find a way to test it to see if that's the problem. To another problem that may or may not be related, the battery won't hold a charge. It's a brand new battery and it worked fine when I first installed it several weeks ago, but when I went to look at the fuses tonight, sure enough, I noticed the battery was dead. I haven't touched the car since I installed the new battery, so I have to assume either the alternator is bad or something is draining the battery. I know there are no lights still on when all the doors are closed, so is there another way to check what could be draining the battery?
vtraudt
May 27, 2012 09:03 AM
MJ2001SE
Jul 7, 2008 09:43 AM
jmcdonaltx
May 20, 2008 10:42 PM
huey215
Nov 20, 2007 07:41 AM
Bony Moronie
Jun 13, 2005 01:37 PM
