2001 Villager Trans. and speedometer
Old Feb 11, 2008 | 09:12 AM
knightwinder's Avatar
1st gear is not shifting right away (delayed shift) to 2nd gear. All other gears seem fine except Sometimes wont shift to reverseright away.
Now two days later the speedometer teters after 50 miles per Hr. The temp is around 15- 20 degrees out side. Trans fluid is clear and full to the mark. There are only 70,000 miles on this 2001 Mercury Villager.
Im thinking about changing the fluid and replacing the filter. Just to cold outside.
Old Mar 20, 2020 | 11:07 PM
13hitts's Avatar
Might be speed sensor . Nice replacement video on YouTube . The easiest way is from underneath, with a little screwdriver/chisel. Chisel out just a little of the aluminium case on the outside corner til you can get under the lip ou the sensor ,they just pop out.
Kevin.Parker
Jan 30, 2015 04:26 PM
curt698
Oct 19, 2010 09:56 AM
jason sereiko
May 22, 2008 09:36 PM
jason sereiko
May 13, 2008 08:35 PM
