Moosing Sound - Not Idle Issue
Old Aug 9, 2007 | 12:43 PM
skidoofan's Avatar
Hello....I've the noise described on these forums typically while idling. The only difference is that it comes and goes while driving down the street?? It's a humming-type noise that I thought maybe the air conditioning system but when turned off, it will still make the noise. It isn't constant but comes and goes. This is my daughters car - 99 2.5 6 with 125,000 miles. It's driving her nuts!! Any suggestions or ideas would be appreciated!
Thanks!
Old Sep 10, 2007 | 09:09 PM
twafflehouse's Avatar
I have noticed the same issue with my 01 and found it to be the water pump tensioner pulley. Both tensioners were making noise at idle but that humming during driving was the water pump tensioner bearings. Doesn't look like I can change the bearings or get it aftermarketso I will be checking with the dealer tomorrow. Anyone have any insight to this as far as aftermarket?
Old Sep 12, 2007 | 09:01 AM
FYI...water pump belt tensioner was $45 from the dealer. This took about 10 min to get off and another ten to put it back on. Once the old one was off I could hear the bearings rumbling very distinctly when I spun the pulley. Woohoo! No more moose on my Merc!
Matt Springer
Jan 18, 2014 06:29 PM
vtraudt
May 27, 2012 09:03 AM
92mercmadman
Nov 8, 2007 08:11 PM
sdbear42
Feb 11, 2006 12:33 AM
Albertaman
Aug 30, 2005 12:10 AM
