1999 Not starting
Old Apr 30, 2025 | 03:35 PM
dlongpine's Avatar
Default 1999 Not starting
The car was hit on the front right side, not to bad, but it did crack the air filter box, knock radiator loose and knock the fuse box loose. There is no check engine light on.
The car will turn over, but not start
The car will not go into R,N, D UNLESS you turn the car over and then change gears. It will only change gears while the starter is cranking.
Any ideas?
Old Jun 7, 2025 | 09:08 AM
FixMyFord's Avatar
Shot in the dark but check the fuel pump reset button in the trunk.
robn
Jul 6, 2013 07:19 PM
kolob
Nov 3, 2012 11:53 PM
ohkate
Nov 17, 2008 06:36 PM
pander
May 13, 2008 11:37 PM
jscranton
Apr 18, 2006 06:37 PM
