Jacking up 1998 Grand Marquis
Old Jun 20, 2019 | 10:49 AM
ukrkoz's Avatar
Default Jacking up 1998 Grand Marquis
Hi all
I just bought a single owner 1998 GM. Not sure on specific trim.
I was planning on major maintenance done this Saturday but, fortunately, came across few posts mentioning something about air suspension and proper jacking with it.
So here's my question.
From what I have noticed so far, mine has a large trapezoidal plug coming out of trunk panel on the left, driver side. About lower tire well height. It also has some sort of a switch up higher on the same side. Factory user guide for jacking mentions that plug as Air Suspension. I started looking into this and that's how I found that AS needs to be turned off before jacking. I, actually, have a scissor lift that I intend to use.
I need guidance on how NOT to screw this up.
Of course, I have only "at a glance"memory of what's in the trunk, as I never even suspected this car to have AS.
Car drives perfectly, it was always dealer only serviced. SO I do not want to screw anything up.
What exactly should I look for and do, before getting her up on the lift? I need to turn rotors, change oil, ATF, rear diff oil.
Thank you
Old Jun 20, 2019 | 01:10 PM
ukrkoz's Avatar
Solved. I have springs. Likely retrofit.
Old Jun 21, 2019 | 11:40 AM
Default Before Jacking Up a Grand Marquis
Originally Posted by ukrkoz
Hi all
Thank you
In order to jack up the car without setting off the Air Suspension --
1. - Disconnect the NEGATIVE Battery Cable at the Terminal.
2. - Make SURE that the cable is disconnected and AWAY from the battery post.
Ford Shop Manual = ALWAYS disconnect the NEGATIVE (-) battery terminal before doing ANY work on the vehicle.
MUST be done to prevent damage to Computer and electrical system.
Suggestions:
Bosch #9606 Double Iridium Spark Plugs.
5-W-30 Full Synthetic Engine Oil.
Bosch #3410 Oil Filter.
Motorcraft Transmission Filter.
Castrol Trans Fluid (Mercon V)
LubeLocker Differential Gasket.
Royal Purple 75-W-90 Gear Oil
Eclipse Calipers; Police Pads; Drilled&Slotted Rotors; DOT 4 Brake Fluid; Centric Hoses.
Cbray1
Nov 26, 2019 10:44 AM
Roberto Martinez
Sep 15, 2018 03:52 PM
OSDCrusher
Feb 16, 2011 02:53 PM
Marquis de Sade
Aug 12, 2010 07:12 PM
09mariner
Nov 9, 2008 08:45 PM
