97 sable idle
Old Jul 19, 2009 | 10:13 AM
coolfool's Avatar
Default 97 sable idle
Hey, does anyone know what the 97 sable 3.0 motor should be idling at? Should it be idling the same cold as hot?
Old Jul 19, 2009 | 05:42 PM
generally yes, the idle should be the same. I think it should be around 800 to 1000 rpm IIRC (if I remember correctly). I may state the idle speed on the decal under the hood with the other engine specs on it (and belt diagram).
Old Jul 19, 2009 | 05:52 PM
coolfool's Avatar
hey there slymer, how goes it? oky doky thanks, Its idling around 900rpms so i guess its ok. i'll check under the hood to see if there is anything there anyhow. Have a great evening
Old Jul 23, 2009 | 08:29 PM
btw, it should run a little faster when cool for "warm-up". If it's already above 90F outside, it may not need to "warm up" first. Though if I remember, the sable/taurus engines didn't have much of a difference between the two states anyhow.
MonteH
Aug 15, 2013 07:56 AM
Jimmyaf
Feb 9, 2012 06:35 PM
RoyM
Apr 26, 2009 06:28 PM
disable
Feb 7, 2007 10:48 PM
disable
Feb 3, 2007 09:28 AM
