jacking front end up questions
Old Dec 11, 2012 | 03:33 PM
cobrahd1999's Avatar
Default jacking front end up questions
This is the only car I evey had with front wheel drive I need to change the front springs and shocks where is a good place to jack it up and place jack stands to work on these parts. Its a 2000 Sable,Sorry about the stuipd question.
PS does it have a cross member and pix would be vry helpfull
Old Dec 17, 2012 | 01:59 PM
sbills55's Avatar
Not a stupid question!!! Look for a steel crossmember ( not the radiator support) there should be a frame under the front that will support the jack!! Then place jack stands under the car ( at the frame or pinch welds) to hold the car while you work.
Do one side at a time and e SAFE!!! I mark the bolts on the struct tower to get the alignment close and then have car aligned...Good Luck!
Old Dec 19, 2012 | 07:04 PM
Thanks again.
87GMARK5.0
Mar 25, 2011 01:32 PM
Jodella
Dec 12, 2010 09:00 PM
bigblkhoe
Nov 24, 2010 05:26 PM
sparky4life
Jul 24, 2009 10:08 PM
cyberfly
Apr 14, 2009 02:09 AM
