Can somebody at least post a response?
Old Jan 21, 2019 | 09:52 PM
mnalep's Avatar
Default Can somebody at least post a response?
I am getting the feeling nobody is here, lol.
Can somebody here please post a response?
Old Jan 22, 2019 | 01:19 PM
Remember the old song --
"There Ain't Nobody Here But Us Chickens!"
Anyways, this site has been hi-jacked by a bunch of foreign pimps.
There doesn't seem to be anybody watching the store.
Old Jan 26, 2019 | 07:03 PM
mnalep's Avatar
Oh really. I guess that explains the lack of any responses. Thanks for letting me know. Why do you say foreign pimps?
That is a song that is new to me...but I just googled it ... would seem to fit, lol ...
Old Feb 2, 2019 | 09:31 AM
Yo, Mnalep !!
Not many peeps come here -- the thread has been hijacked by "Escort Services" (pimps) from foreign lands.
I'm presently the most active member, but I don't come here every day (sometimes only weekly).
Thanks-a-ton for the U-Tube post -- Brought back old memories from when I was a kid during WW2.
You got a Mercury !?? If so, what year and model ??
As my handle suggests, mine is a '95 MERC -- Grand Marquis GS -- major restoration. --
set up for long-distance, hi-speed touring through the deserts and mountains of the American Southwest...
​​​​​​1995 Grand Marquis GS Restoration.
Engine is basically stock, with no internal modifications.
Items marked with "#" are/were available for purchase at Amazon.com.
Intake Air Box Snorkel removed - cool air is ducted from forward of the engine compartment.
# K&N *33-2272 Re-usable Air Filter.
# Bosch *69128 Electric Fuel Pump.
# Bosch *68015 In-Tank Fuel Filter.
# Motorcraft *FG800 In-Line Fuel Filter.
# Mallory *4213 Adjustable Fuel Pressure Regulator -- 35 psi. @ 800 rpm.
# Bosch Series 3 - 19 lb. Fuel Injectors.
# Bosch *09725 Mag-Core Ignition Wires.
# Bosch *9605 Double-Iridium Spark Plugs.
# Motorcraft *PW357 Water Pump.
# Motorcraft RT 1103 Thermostat.
# Motorcraft *YB541 Fan Clutch.
# Bosch *15717 Oxygen Sensors (4).
# Bosch *SR7533N Starter.
# Bosch *AL7537N 130-Amp Alternator.
# Gates *K060980RPM RPM Series Serpentine Belt.
# Gates *38386 DriveAlign Belt Tensioner.
# Motorcraft *KM2973 Upper Radiator Hose.
# Motorcraft *KM2969 Lower Radiator Hose Assembly.
# Dorman *624-107 Electric Fan Assembly.
# Motorcraft *YC166 Air Conditioning Compressor.
# Four Seasons *38904 Severe Service Orifice Tube.
# Behr *351214031 PAO Compressor Oil.
# Dual Exhaust - Walker *40383 H-pipe.
# MagnaFlow *18134 - 2" x 3.5" x 21" Glasspacks.
# Walker Tail Pipes - *46761(right side); *46789 (left side).
# Superior *28-6201 2 1/2" x 6" Stainless Steel, Slant-cut Exhaust Tips.
# B&M *70268 13,000 b.t.u. Transmission Cooler Kit.
# B&M *40264 Transmission Shift Improver Kit.
# B&M *80250 Transmission Drain Plug Kit.
# XPERT Performance Cast Aluminum Differential Girdle.
# LubeLocker *LLR-F880 Differential Gasket
# Energy Suspension *4.3150G Urethane Control Arm Bushings (upper & lower)
# MOOG Greasable Ball Joints, Tie Rods, Idler Arm. (front)
# MOOG *K8853 Greaseable End Links (front).
# Motorcraft *HUB3 Wheel Bearing Hubs (front)
# ADDCO 1 1/4th" Front Anti-Sway Bar, with Energy Suspension Greaseable Urethane Bushings.
# ADDCO 1" Rear Anti-Sway Bar, Urethane Bushings.
# Energy Suspension End Links with Urethane Bushings (rear).
Eclipse Brake Calipers (front & rear).
# ACDelco Drilled & Slotted Brake Rotors (front & rear).
# Motorcraft Police Brake Pads -- BRSD678 (front) & BR107B (rear).
# D.O.T. 4 Hi-Temperature Brake Fluid.
# 98T (118 mph) Goodyear Assurance ComforTread Touring Tires.
5 "Italian Lace" 15" alloy wheels (includes spare).
# 9006 (Lo-Beam) Cougar Motor 6000k L.E.D.s.
# 9005 (Hi-Beam) Cougar Motor 6000k L.E.D.s.
# HELLA *980860801 Daytime Running Lights.
# Dorman *38445 Door Strikers.
# Garmin 66LMT Navigation.
Limo-Tinted Windows.
Custom Headliner by "Hot Rod Interiors", Glendale, AZ.
Dual Exhaust system welded up at "MufflerMasters", Avondale, AZ.
** All parts installed on this vehicle are certified and guaranteed to be GLUTEN-FREE !!
*** No animals were harmed during this vehicle restoration.
Quarter-Mile = 16.2 sec. @ 88.6 mph.
NotThePlanetMercury
Sep 6, 2019 07:27 PM
txrob779
Jun 14, 2017 03:09 PM
95 MERC
Mar 12, 2017 12:46 PM
95 MERCChuck Hallowell
Nov 29, 2016 01:27 PM
